RE: Structural failure/ Extreme elevator flutter on Somenzini 72" Yak?
Hi Guys
We have in the old days been lucky regarding flutter with small aircraft and therefore relatife stiff control systems. As the aircraft got bigger flutter became a problem as the total stiffness of the structure goes down. To cure flutter you must mass balance and seal the control gap, and have a stiff servo-control surface link.
I think it is unfair to call an airframe defect when you are not willing to install the above. Flutter speed depends heavily on the stiffness of the structure. So a small change in the density of wood in the control surfaces can have a major impact on the flutter speed. Changes manufacturers cannot really predict.
So I say: Dont be lazy, seal airtight, mass balance and fly with confidence.
Airasj ( full scale flutter analyst)
