I have never messed with the cam gear, just open the box and fly it
I was measuring the temp on the surface of the parts, with the bellypan removed. I am quite sure that one could read many different numbers depending on how and where the thermocouples were mounted.
ORIGINAL: wolf123
Hi
I measured the temp in header,not on, like EGT in turbine.
Another question, how you set cam gear? Like Dave Shadel piston TDC and dot on cam stright up or like Yamada says dot on crankshaft straight down and dot on cam straight up? Because there's about 15-20 degrees of difference on cam timing.
Regards
