RE: OS 40 LA / AVISTAR SELECT
What makes you certain that the needle valve is set correctly? It sounds too lean.
Did you mess with the air-bleed screw? Where is the air-bleed set at? Normally when you look in through the bleed hole, the air-bleed needle is half way across the opening.
