RCU Forums - View Single Post - The dumbest Question ever
Old 10-20-2004 | 09:34 AM
MassiveMods's Avatar
MassiveMods
Default RE: The dumbest Question ever
way i clean is this..
Brush off all major stuff... with a brush
Blow off with compressor
take out servos
Coat car with oven cleaner
Sit for 20 to 30
Go over with tooth brush and bottle brush and Jif
Rince under hot water
Blow off with Compressor
Dry with towel
Sit infront of heater till completely dry
Completely spray car with electrical silicone spray
Wipe off excess
Voila should take about an hour
Little trick, put a bead of silicone sealant around the little socket that you attach the horn to, let it dry and put the servo horn back on, will stop about %50 of dust and some moisture getting in..
