RCU Forums - View Single Post - HInge Points
Thread: HInge Points
Old 10-20-2004 | 07:57 PM
mikeboyd
Default RE: HInge Points
Another variation, using Hinge Glue, pacer company. After you roughen the outside of the hinge points with sandpaper, you can fold them over tightly and wick some oil (wd40 okay) into the hinge, careful not to get oil on the surface area you wish to glue. Pacer glue is like thin resin glue and is a little runny, so it can be put liberally into the prepared hinge point hole. If you have wiped the covering around the hole area with oil, or not, the glue can be easily cleaned off with water, even after dry. The glue causes the bulsa to swell and seal the hinge point tightly into the hole. Good reliable, easy to use specialty glue for hinges. Enjoy the easy application and clean up.
