RCU Forums - View Single Post - P80 problem
Thread: P80 problem
Old 10-23-2004 | 06:04 PM
JSF-TC's Avatar
JSF-TC
Default RE: P80 problem
I had exactly the same Fuel Fail on the initial ground run following a JetCat service and the 5.0 ECU Upgrade. Duirng the run, the sound was very different, a deeper note with a very pronounced rumble. All of a sudden, it shutdown with a Fuel Fail message. I ran it again, and everything was back to normal, so I put it down to purging all the fuel lines, and possibly uneven combustion causing the rumble.
Hopefully Matt can describe the faults that generate a Fuel Fail message as it's not in the manual.
Paul
