RE: Engines and Mounting
Use a Sullivan flexible nyrod to hook up the throttle. A couple of clevises and some all thread is all you need. You put the outer casing in and epoxy it in. Then just fit the inner so you have some allthread (2-56 size by the way available from dubro at most hobby shops) in the ends to screw the clevises onto and you are done. Good luck with it.
Mark Shuman
