RE: My BUGGY STARTED TO REVERSE HELP!!!!!!
Engines with a functional PS (installed properly and has no defects) cant run backwards, even if your using a starter box.
The PS will engage and retract which immediately stops the engine.
Engines without PS can be started in reverse, but runs poorly.
Did you charge the SB battery between tanks, then hook the SB battery up backwards?
