RCU Forums - View Single Post - The Ignition line is TOO LONG
Old 10-25-2004 | 08:06 PM
tkg
Default RE: The Ignition line is TOO LONG
Carefully remove the spark plug boot and see if the plug lead is wire or something else. If its stranded wire (very likely) just cut to length and reinstall the clip and cap.
Did you make a new key in the flywheel to correct from moving the coil??
