RE: Genesis pull starters
Powerslave,
Here are a few tips. When you are priming the engine. Make sure that you prime it until the fuel JUST enters the carb. This is all that is needed. Literally only a second or two of priming in needed. If you prime it too much the engine floods and the ROTO-Tech Starter will struggle when trying to start the engine. Remeber, only minimal priming is needed. Also, always make sure that you charge your battery. There is nothing worse then going out to run your truck, Getting to your destination or track, and your battery begins to die while starting the truck.......
CEN RACING
