RCU Forums - View Single Post - Flip- what do you think?
Old 10-28-2004 | 02:01 PM
Rhilluk's Avatar
Rhilluk
Default RE: Flip- what do you think?
when mine goes into the prop hang it makes a weird buzzing sound.
However easiest way to get over the rudder is to not use the supplied tail wheel, either use a peice wire (rudders big enough for ground control) or another wheel attached by elastic band. My landing gear area is also quite weak. Seems to be some hard balsa instead of ply.
