RCU Forums - View Single Post - Genesis pull starters
Old 10-28-2004 | 03:37 PM
homerxp
Default RE: Genesis pull starters
BILKO1
yes the shell was scratched due to packing but everyone i looked at was the same so no point in complaining cause your right they don't give a toss.
powerslave
You would be a bit pi**ed off aswell if you lived in the Uk where the only support you have for these trucks does not want to know. I am sure if we did have Cen support in this country we would be able to all sort out our problems but we dont, and as for following the guidelines of operation there is not much you can do when 2 new cen failsafe fail in a row and write off the front of your truck, me one time and the model shop had the same problem with a new failsafe when i took it back, so had 2 new front ends and im sure the model shop knows what they are doing even if you say i do not which i can assure you i do. Have you thought that maybe people want to know the problems with these trucks so they know what to expect when buying one, think about that. And do you think it is right then for a main supplier to ignor any letters of complaint ?
Fitted the new GS 092 Dogbone lastnight and guess what within 10 minutes of running it today (in first gear only as I'm still running it in) the pins fell out once again. Guess that will be yet another 2 weeks with no truck [&o]
I really could understand these problems from a truck that had been raced a few times but this has no more than 3 hrs running time.
