RCU Forums - View Single Post - How do get these darn things started
Old 10-28-2004 | 03:50 PM
Nitro Rustler Racer's Avatar
Nitro Rustler Racer
Default RE: How do get these darn things started
okay when the engine starts rev it up to a little more to half throttle and take he ignitor off and let the truck drive keeping the throttle in that position, should i work i hope
ORIGINAL: jakjr
I dont know, I just treid it again today and it does the same thing. Everything works perfectly fine until I take the glow plug igniter out. It isnt the batteyr as I just replaced it last night and this is the first time ive used it.
The engines running perfectly, reves up to full throttle, brakes work, everything works perfect, until I remove the igniter. I tired startign it rich then leaning, then removing the igniter, same thing. Also tried starting it lean then richining, then removing the igniter, same thing. just dies instantly.
The glow plug looks fine, as far as I can tell all the coils glow nice and red.
The only thing Ive noticed is when I remove the igniter I cna see some little bublles coming up around the plug, could this be the problem? The manual says its due to a bad gasket but I dont see how that would make it dies when the igniter is removed.
The only thing I can think of trying is to replace the glow plug and gasket. Or keep adjusting around on the motor?
The motor also has a low speed valve and a idle rpm set screw, mayeb one fo these are set wrong?
