RE: How do get these darn things started
I fixed the duratrax servo, turns out this old futaba servo I had has the excact same gears in it. Oh and I figured out why the first one stripped, the servo saver was set (from the factory) to such a high tension it was basically useless, ive now loosened it up nearly as loose as it will go.
I think my motor is probobly pretty well broken in now, I ran like 10 or 11 tanks through it today. I think its running richer than the recomended setting so tommorow ill have to even it out.
Now the only problem im having is if you stop or start abruptly the motor dies, whats weird is it doesnt do it every the time, just maybe half of the time. How do I fix this? or will it fix itself as the motor finishes breaking in?
