ORIGINAL: SnApRoLl-2
I've been in the amazing and awsome hobby since 1976 and I've seen many pilots try to fly a plane beyond his or her capabilities and when they crash they try to find fault in everything
else such as machanical or structural failure etc... and not fault them selves. I've dumb thumbed
many airplanes I'm not ashamed to admit it. I've even tried flying planes I should have never attempted, I tried to fly a Laser 200 right after I learned to fly a trainer, it put a hole in the paved runway I was flying from. I chalked it up to the oop's I messed up column. Did it make me a bad guy? No it did not. But it did however make me a better pilot. Unfotunatly bad things can happen when trying to cheat gravity. its part of the learning curve.
Bad or flawed design? The Funtana 90 may fall into this catagory slightly. The Funtana 90 is a fairly new release and maybe Hanger 9 should have done more flight testing and or structural
research before releasing it to the public. I will say this though Hanger 9 should have definatly packaged the plane a little better. Unfortunatly arf's are built by humans and to err is human.
As far as critisizem goes I think we should critisize a designer or a pilot as long it is constructive. I have designed a few C/L
model's that others have flown and I took constructive critisizem, it allowed me to find flaws in my designs so I could build a better model. also critisizing a pilot/designer even if you've never designed model before is not silly. there are many pilots that feel they have ideas that can make a design better. after all our hobby was started by an idea.
Snap,
This is the best post on this thread. Well done! This sums it all up. Enough with the name calling, and attitudes.
