RE: PT-40: Help fixing a binding nose gear steering wire
Be sure that the arm is close to the firewall with the nose wheel straight ahead. There really does not have to be a ton of travel in a nose wheel. A little goes a long way. Most binding occurs if you have the arm too far out. The pushrod leaves the outer casing and has to turn toi get to the arm. Straight on is the best way to describe how you have to hook one up.
Mark Shuman
