RE: Need advice
Is that buggy sitting on something in that picture or do you have the ride height set that high????
Looks like the fronts are warn bald too,
Recomendations??
First have the buggy set closer to a-arms level and have no more that negitive 1-2deg camber
I'd raise the camber link to the upper inside hole on the shock tower too, that will take out a lot of the camber change through the arm travel
Second, if you're not racing get some stiffer compound tires
Those ofna "colorz" X patterns are crappy tires anyways
If you're running in hard pack try Knuckles or if you're just bashing the "Badlands" are very good too
