Hi! Mike
First of all here is my Configuration:
Tx Sanwa (old) Pcm 6p 6channel 41Mhz (41.020Mhz crystal)
Rx Hitech Feather receiver /Single conv. 40Mhz (41.020 crystal)!
I use the above configuration to fly my LiteStik
The problem is that I have a dramatically reduced range (18-20meters)
As you have noticed I'm using my Sanwa Rx crystal at 41.020Mhz
although the hitech feather is at 40Mhz range!
I was thinking that was not a problem (or MAY BE IT IS?)
Would it be better to have a hitech crystal at 40Mhz range (on the receiver) and put a 40Mhz range on my Sanwa Tx too??
PS: what exactly is the job for theese crystals, as
I can figure out they have the roll of some kind of "filltering"
for the oscillator circuit on Rx & Tx?
Regards,
Alexander
GREECE
