RE: PT-40: Help fixing a binding nose gear steering wire
Nice looking job, but it was a lot of work. I have found that mounting the main gear bolt-down block on the floor of the fuse, tight against the back side of the former, works very well & you can easily get at that location from the open battery/servo bay. This puts the wheels just under the leading edge, which is a good location. If you get the wheels too far forward, the take-offs can get squirrely.
