update.
Got alot of work done, lot more than usual.
Have set up the aileron linkage. Mounted the big balsa blocks for the tips, which will require some serious sanding..
The tip has a plywood spacer in between the upper and lower tip block, should protect the wingtip from some dents.
The upper sheeting is in place except from the front upper bearer to the leading edge.
Doesn´t sound like much work when you say it like this thou.
well, some more pics. One of the internal link system. Tested it and it works really great. Totally slop free.
Its nice to se one wing half being closer and closer to finished.
But then I have one more to go
