RCU Forums - View Single Post - Help with 9C and Ultra Stick programming
Old 11-03-2004 | 10:12 AM
Frogman1195
Default Help with 9C and Ultra Stick programming
Hey,
Manual on Ultra Stick said to setup 9C in Glider mode. This takes away the throttle cut and snap roll functions. Can I add snap-roll and Throttle cut to glider? Or can I set up all the glider functions in the aero mode? I have four servos in the wings for seperate flaps and ailerons. I would like them to function properly as Flapperons and Flaps. If this can't be programmed I'd like to at least have flaps with elevator mixing. So far I have not been able to get the Channel 1 and 7 servos to work with Flaps in the Aero mode. Flaps are on channels 5 and 6.
Dave
