Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Help with 9C and Ultra Stick programming
Old 11-03-2004 | 10:12 AM
Default Help with 9C and Ultra Stick programming
Hey,
Manual on Ultra Stick said to setup 9C in Glider mode. This takes away the throttle cut and snap roll functions. Can I add snap-roll and Throttle cut to glider? Or can I set up all the glider functions in the aero mode? I have four servos in the wings for seperate flaps and ailerons. I would like them to function properly as Flapperons and Flaps. If this can't be programmed I'd like to at least have flaps with elevator mixing. So far I have not been able to get the Channel 1 and 7 servos to work with Flaps in the Aero mode. Flaps are on channels 5 and 6.
Dave
Old 11-03-2004 | 02:49 PM
Default RE: Help with 9C and Ultra Stick programming
Hi Dave,
You would want to set this up in Acro mode with the 9C. Also please check our FAQ's they can walk you through this step by step.
http://www.futaba-rc.com/faq/faq-9c-q515.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Progamming Technician
Old 11-04-2004 | 05:58 PM
Thanks Krysta I'll give this a try.
Dave
