RCU Forums - View Single Post - Mosqitobite TriPacer Build started.
Old 11-03-2004 | 11:42 PM
wascamp
Default RE: Mosqitobite TriPacer going on the workbench.
Mike (MegaMang) should post a picture of his T-Rex. For those who have not seen it....Whow!
Well today was one of those grunt work days. Soldered the gear join and fit the leg fillers. As mike and I talked about in a post above the join of the two gear wires is sort of old school. You will see what I mean about it works but it's not pretty. It gets covered up later and hopefilly it won't look too bad. The last two shots are just to show the filling I did on the nose and scoop. It's not extensive, just a little to smooth out the transitions of the sanded layers. I am at that point in every build where things start to get sanded. I finished rounding the edges of the control surfaces : that reproduces the real airplane which used steel tube build the tail members.
Dont forget the offer, jump in at any time with questions or comments. Glad to have some expert help. I may even ask MegaMang to cover mine. He is good!
ID:	189715   Click image for larger version
ID:	189716   Click image for larger version
