RCU Forums - View Single Post - Your Battery choice for electric (F3A) pattern???
Old 11-04-2004 | 09:51 AM
darkvader's Avatar
darkvader
Default RE: Your Battery choice for electric (F3A) pattern???
Hi Tony
My configuration is:
Composite ARF Impact with Hacker C50 14XL Acro (timing set to +3 degrees), Hacker master 77 controller, APC 22-12E prop, and 10S3P TP6000mAh GEN2 Yellow stripe Lipo packs.
The 10S3P TP6000mAh GEN2 Yellow stripe Lipo packs have about 48.85 oz (1385gr) - too heavy.
The all complete set has 11.50 lb.
I've now 14 cycles in one set of packs.
After a P05 flight ( 6 ... 7 min. ) the temperatures are the following:
Motor: between 51ºC ( 123ºF) and 60ºC (140ºF)
Master 77: 40ºC (104ºF) - (curious ?!)
Lipo pack (measured on the top back part): between 41ºC (106ºF) and 47ºC (117ºF)
Have you any figures from your experience with your equipment, please?
What are your filling comparing the Gen2 Yellow stripe and the Gen2 Lites (grey stripe)?
