RCU Forums - View Single Post - 60 size float setup?
Old 11-04-2004 | 07:36 PM
JimCasey's Avatar
JimCasey
Default RE: 60 size float setup?
Put the step under a point 3/4 to 1" behind the balance point of the model...projected down whe the plane is sitting level above the floats. If your floats are sized properly, they will then stick out a bit in front of the prop. GP .60-size floats are HUGE and will handle most .90 size planes.
