RCU Forums - View Single Post - CG ex-treme 330 ?
Old 11-06-2004 | 09:56 AM
Flyboy1958
Default RE: CG ex-treme 330 ?
12 inch extensions work good, 18 if you want to really give yourself enough room to lplay with. You have to cut out the back side of the plastic rectangular tube and connect the extensions at that point. I also used a piece of dental floss to wrap around the two where they connect to make sure they don't vibrate loose, it worked out well.
