RCU Forums - View Single Post - Not the outside, but the inside of a jet
Old 11-07-2004 | 01:45 PM
icepilot's Avatar
icepilot
Default RE: Not the outside, but the inside of a jet
Hi Paul!
Here are a couple of pictures inside my SpiderJets F-16. The clever thing about the SJF-16 is that there are 2 main bulkheads where practically
all your jet equipment fits - most of it has even been CNC-routed to accept the items of your choice.
Here you can actually mount all your equipment before you install the bulkheads in the plane - meaning you will be able to
test everything while you still have excellent access. This idea can easily be adopted to most other jets.
It makes the installation both easy and clean.
One important issue is your leads. Make sure that all your leads are strapped or fastened so there is no chance for them to move around
in a high G maneuver - even a very light lead or connector gets very heavy at 6-8 G's!
Good luck with your first jet!
Tor
ID:	190721   Click image for larger version
