RCU Forums - View Single Post - Bouncy tail dragger...
Old 11-10-2004 | 03:43 PM
Fastsky's Avatar
Fastsky
Default Bouncy tail dragger...
I built a Cloud Dancer 60 from plans. Its about 8 1/2 lbs. Its easy to take off and a great flyer but the landings are something else. I believe the problem is that the gear is so stiff that if I get the slightest bit of a bump during touch down, the plane starts bouncing down the runway. Therefore I am only flying it on really windy days so that I can slow the plane down to almost a hover before touching down. I want to replace it over the winter and am looking for suggestions. I really want to get rid of the bounce on this plane so cost really isn't an issue if there is something that works well. Do I use Dural aluminum or should I go a bit heavier duty such as fiberglass gear?? []
