RCU Forums - View Single Post - If it ain't broke....
Old 11-10-2004 | 06:42 PM
Gravityisnotmyfriend's Avatar
Default If it ain't broke....
Fix it till it is. This is an old electric Chimpmunk. The motor it came with was huge (its in some of the pics) and I thought that a newer smaller motor would be better. I thought I could get the same power with less wieght. Obviously I was wrong. With the old motor. it would take off from the ground easily and maintain altitude at 1/2-3/4 throttle. The new motor it was way underpowered for this plane. I did get it to ROG with a fresh battery, but I had to keep WOT to maintain altitude. After 4 short flights (3 hand lauched) I tried one more. I threw the plane, and it got up about 20' before it stalled. I thought I could pull out, so I left it full throttle. And that's how she hit. I've already got humpty dumpty put back together again, but with the same motor I started with.
ID:	191949   Click image for larger version
ID:	191950   Click image for larger version
ID:	191951   Click image for larger version
