RCU Forums - View Single Post - CT4-S Setup
Thread: CT4-S Setup
Old 11-10-2004 | 07:10 PM
CEN Racing's Avatar
Default RE: CT4-S Setup
John,
We have been considering implementing setup sheets in our manuals. You may see them shortly. Below are the recommended settings for the CT4-S. According to our Team Drivers.
Thanks for your question and interest in our products.
Camber: A good starting camber for most conditions is -2 degrees all around.
Toe in: Rear: 2-3 degrees
Front: none- negative 1 degrees
Shock oil: Use apx 30 wt oil with the stock pistons all around.
Springs: Silver is a very good starting point. The next spring to try is a bit stiffer. Our white spring. This will make your car much more reactive and twitchy however.
Ride Height: Run apx 4 mm-4 1/2mm of ride height in the front and 5mm ride height in the rear.
If you need more direct set-ups for specific track conditions etc. you can email [email protected] he can help you out in detail. Thanks for your question once again.
CEN RACING
