CT4-S Setup
BC, CANADA
What is the recommended setup for the CT4-S? I would like to know what CEN recommends for camber, toe in, shock oil, springs, ride height etc. Does CEN produce setup sheets like some of the other manufacturers do? This would make it much easier to keep track of settings for different situations.
John
John
CA
John,
We have been considering implementing setup sheets in our manuals. You may see them shortly. Below are the recommended settings for the CT4-S. According to our Team Drivers.
Thanks for your question and interest in our products.
Camber: A good starting camber for most conditions is -2 degrees all around.
Toe in: Rear: 2-3 degrees
Front: none- negative 1 degrees
Shock oil: Use apx 30 wt oil with the stock pistons all around.
Springs: Silver is a very good starting point. The next spring to try is a bit stiffer. Our white spring. This will make your car much more reactive and twitchy however.
Ride Height: Run apx 4 mm-4 1/2mm of ride height in the front and 5mm ride height in the rear.
If you need more direct set-ups for specific track conditions etc. you can email [email protected] he can help you out in detail. Thanks for your question once again.
CEN RACING
CEN RACING
