RCU Forums - View Single Post - Your Battery choice for electric (F3A) pattern???
Old 11-11-2004 | 03:16 AM
MAaltonen
Default RE: Your Battery choice for electric (F3A) pattern???
Hi,
I am using LMT - Lehner setup in ZNLine Synergy.
I think the battery selection is based on the plane and personal requirements. If the plane is heavy or you prefer flying with power you will need battery that can deliver a lot of current with high voltage to have enough power.
If the plane is very light then you are able to use smaller C-rated and capasity cells because light plane does not need so much total energy to complete the schedule than heavy plane.
Based on that I am using Kokam 2000mAh cells as 10s2p, the pack weight is 1100g.
Motor is 2230/15+superchief gearbox 6:1
Prop is 17.4*12 RASA turning 7500rpm on ground with 69A.
Plane weight is 4450g.
P-05 schedule will consume around 3300-3400mAh which was unusually high. After that the motor+gearbox went to service and they found faulty bearing in the motor which was replaced with no additional cost. I expect that after the service the consumed capasity will be lower and prop RPM to be higher or current lower. After flight the battery temperature is lower than hand warm.
BR. Markus Aaltonen
