RE: Please help with .91 pipe coupler!
Normally, there is a small ring which slides over the pipe end that couples to the engine. The ring will have a spring or wire with tie screws that goes around the engine cylinder. As for coupling the two pipe pieces together, I always used a silicone coupler made by Pranther. Normally used for boats, etc.
Hope this helps.
JR Gautreaux
