Cloud Dancer 60 tank problems
Hey all, I'm having a problem with my Cloud Dancer 60. I'm flying it with the engine inverted and starting it is a real bear to say the least. The engine floods ( typical inverted engine ) and then it takes all I can do just to get it started. Fuel will run out of the tank just sitting on the flight line. This is a stock mounted tank that came with the kit and everything is installed as per the instructions. I'm wondering if I lower the tank about 1/2!QUOT! if this will help the situation. Any suggestions appreciated.
