RE: brian taylor, 73 inch typhoon
Your typhoon looks great, Ive been giving your comments a lot of thought.
See i hate bellcranks true ive never lost a plane to bellcrank faliure but somehow slack always seems to seep into the system somewhere,
On this model you will need to run about two meters of wire down the wings to the bellcranks, this weighs about 1/4 what the extra two servos do true,
I have 7 servos in that wing 2 aleron 2 flap 2 retract 1 door servo. 5 of which are an inch aft of the cg fully loaded thats legs retracts wheels etc but un covered it ways in a 3 1/2 LBS out of plane thats spec weight is 13LBS
The tail is as specified.
Are we spliting hairs over an extra two servos, is it trully that critical?
I've always felt that the covering will be what makes the differnce.
