RCU Forums - View Single Post - Shogun tip
Thread: Shogun tip
Old 11-14-2004 | 08:37 PM
rotarguy
Default Shogun tip
Just a word for caution. When you set up your shogun make sure the tail is snugged close to the motor gear. I had the misfortune of not snugging mine close enoujgh and damaged the gear. (started to strip in one area) I took a knife and recut the gears and moved the tail closer and it seams to be fine now Kind of messed me up when the tail response died. Make sure your gears are fairly tight!!!!!
