Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Shogun tip
Old 11-14-2004 | 08:37 PM
Default Shogun tip
Just a word for caution. When you set up your shogun make sure the tail is snugged close to the motor gear. I had the misfortune of not snugging mine close enoujgh and damaged the gear. (started to strip in one area) I took a knife and recut the gears and moved the tail closer and it seams to be fine now Kind of messed me up when the tail response died. Make sure your gears are fairly tight!!!!!
Old 11-14-2004 | 10:43 PM
jbalat's Avatar
Default RE: Shogun tip
I have gone for a bevel gear setup from tedani. I will post some pictures tonight but results look good after the first flight...
Old 11-15-2004 | 09:51 AM
keep me informed as to durability and performance please. Could you posts http link
Old 11-15-2004 | 09:58 AM
I found tedani. Not sure how the bevel gears work Pics would be great. Thanks
Old 11-16-2004 | 05:55 AM
jbalat's Avatar
Check out the bevel gear setup.
After my third flight and a few light tail hits on the grass, the gears are still going strong
ID:	193428   Click image for larger version
Old 11-17-2004 | 01:22 AM
Thanks for the pics I've been doing more reserch and noticed blue gears somewhere. I'm going to try and find some gears locally but if not I'll give tedani a try.
Thanks again
Old 11-17-2004 | 06:09 AM
jbalat's Avatar
Did you say 'BLUE' gears ???
I am happy with the bevel gears for now, they seem quite durable.
Old 11-17-2004 | 01:12 PM
You can get the blue bevel gears from www.microheli.com
