RE: HEAD FOR ST-3000
You might try cleaning it as good as possible, then using some thin green loctite on it. you have a better than fair chance that it will seal. The loctite is good for about 350 deg. and the brass should cause it to set up. Good luck. Also after you give it the treatment be sure to clean off all the excess loctite, (after letting it cure or removing the glow plug might become more difficult).
