RE: Phoenix Funstar 3D 46 ARF
Dude ... do a search in this matter, its been asked before. There is nothing about this plane that you really need to be aware of other than:
- Throttle linkage, you need to make guides using small balsa blocks, the linkage will get pushed by the wing if you do not make a guide
- Rudder/Ele horns ... watch out for this as when you use maximum throw the elevator and rudder horns can touch, esp when you are doing a snap roll
Other than that she is a breeze to build.
