RCU Forums - View Single Post - Pattern ARF/ARC wanted 72" long or less
Old 11-15-2004 | 09:56 AM
MarkGrabowski
Default Pattern ARF/ARC wanted 72" long or less
I've been tooling around the various forums and sites checking out the various arf/arc aircraft suitable for pattern. I happen to have two n.i.b. Bully 120 rear exhaust that I'd like to see put to good use. I'm looking for suggestions on some suitable arf/arc planes that are UNDER 72" in length.... I can fit a full 2 meter bird in my truck BUT if I stick with 72" I can transport the plane without a lot of monkeying around and shifting things to fit in the back of my truck. My first preference would be a "true" pattern ship but I understand there are certainly suitable 3-d type and imac type planes that would fit my needs as well. I'm only a sportsman level pilot so don't exclued planes that wouldn't work for an FAI pilot but would be fine for me. I will be running a bolly exhaust pipe out the back and do realize that it might not fit the belly pan if said plane was initially designed for a four stroke. That doesn't really bother me that much...after all, that look was all we knew when we ran 61 engines and put the pipe under the wing!
Mark Grabowski
