RE: Cloud Dancer 60 tank problems
IT WILL COST A FEW DOLLARS ( AND WHAT DOESN'T TODAY ) BUT YOU CAN INSTALL A PERRY PUMP IN THE SYSTEM AND THAT SHOLD END THE PROBLEM. I DIDN'T HAVE THIS PROBLEM WITH MINE WHICH WAS AN ARF WHEN THE PLANE SAT ON THE GROUND, THE NOSE WAS HIGH. I HAD THE WING MOUNTED LANDING GEART AND TAIL WHEEL.
IT WAS A GREAT FLYING AEROPLANE WITH AN OS 91 FOUR STROKE.
I ALSO USED A THIRD FUEL LINE FOR FILLING AND I RAN THE THIRD LINE TO THE BACK OF THE TANK WITH A LINE AND CLUNK. THIS WAY THE LINE CAN BE USED FOR FUELING AND DEFEULING.
GOOD LUCK
FLASHINGRED
