RCU Forums - View Single Post - Mosqitobite TriPacer Build started.
Old 11-15-2004 | 06:07 PM
  #48
wascamp
Default RE: Mosqitobite TriPacer going on the workbench.
No Mike, the sun is shining thru the daylight basement windows. That is my shop for now. I setup in the guest room to build the fuselage and sub assemblies. Moved into the basement living room to build the wing on an eight foot long temporary work bench. I am still working on sheeting the trailing edge and adding the rib caps. I am still very much under the weather and can only work on the Tripe for short periods.
