Electrical interference
Is your antenna completely collapsed? If so, 120 feet is not that bad. If you have several inches of it sticking out, then I would expect more distance. Also be sure you have a good tight connection with the plug lead and its ground and that there are no metal parts on the plane moving or jiggling against each other.
