RE: Twin Engine Questions
Ed, sounds interesting, BTW I went to the Cocoa Bch area, had a great time but took only land planes.
Here's what I put in my first post, above, about counteracting engine torque.
"I recommend slight upwards thrust on both engines(3-5°) and outward thrust on each(3-5°) if you want to counteract engine torque you can reduce the outward offset in the right engine a little and increase the offset in the left engine."
Obviously the best solution would be one normal rotation and one counter rotation engine.
