RCU Forums - View Single Post - Ez Start Vs Pull
Old 11-17-2004 | 08:46 AM
travis28379
Default RE: Ez Start Vs Pull
U Guys are missing the point it DOES NOT have a EZ start System. Its is rigged up to crank with a starter box. He is asking should he buy a starter box or change it over to Pull start.
All you would need for pull start is the crank shaft and the pull start and the pull start "gear" or what ever u call it.
If i was you i would get a starter box. I actually have one thats kinda old but it still works would u be intrested in buying it for pretty cheap??
}{unter
