SKYMASTER F-18 HELP NEEDED
Hi,
I would be thankfull if someone can help me with the following:
1) I just can't get the Flap servos properly alligned to work with no tention....(I have chosen the method where the servos are in side the fuse on the SM page) Any tips?
2)This is my first inside istalation of a turbine and am trying to figure out wether the aluminum bell mouth which is loose, is to be used or not(in the bypass) and what clearance between nozzle and pipe ?
Thanks in advance
Eray Savci
