RE: Panacea
Bill I have the Panacea also and had the same minor problems but an easy fix the canopy was taller than the fuse we both just cut the seam line on the fuse and spread it out to match and reglassed the seam form the inside a little filler and done, do it before firewall install and you won't even be able to tell it don't have to cut all that far about half way to spinner.
Steve Maxwell
