RCU Forums - View Single Post - DP Edge540T 26% question
Old 11-24-2004 | 01:29 AM
Flyrite
My Feedback: (73)
Default RE: DP Edge540T 26% question
Just unscrew the servo screw and remove the horn, to re-install center the elevator with the radio and the servo arm should re-center, or you could mark it, the only problem here would be if you are using metal gear servos, it would require loc-tight everytime you re-installede them, what a pain.
