RE: Gorilla Glue for wing joint?
Thanks for all the reply's.
Got the wing glued up now and was surprised there wasn't a lot of foam to deal with and it sanded down relatively easily. The joint was very tight before I glued it except for a piece I believe they called spar brace. It was three laminated pieces of 1/8 " ply that slipped between both upper and lower spars on both wings then glued in. it fit in very sloppy which was why I though the foam action in that spot would help. Thanks again Kev.
P.S. the joint seems to be very strong, but the only true test will be on the bottom of a loop right. <grin>
