RE: Onboard Alternator
I'm sure it is possible and I'm sure someone will do it soon.
I guess a slight problem is the RPM involved. An electric motor (alternator) will probably not stand up to 160,000 RPM. A gearbox will be required which will add considerable complexity to the relatively simple model engines. I guess it would be pretty easy on a turboprop that already has a gearbox.
